2x 12v adaptors to dimmer2
I have a fibaro dimmer2. And 2 adaptors to 12v. 1 adopter controls 2 spots and the other 5. I connect both adopters to the same dimmer2. All lights go on but the adopter with 2 lights directly switches off. Any suggestions? I will try tomorrow to switch the plus and min of one of the adapters.
Would that make sense?
Edited by RIck
Are you sure the adapters are dimmable? Also you could use a Fibaro RGBW device instead (it operates from 12v), that way the adapters don't need to be dimmed
