kevin 34
Since today I suddenly cannot turn OFF the lights by using the wall switch, the lights and wall switch are connected to the same Fibaro Dimmer 2 module. It is the room of my 6 year old son, he would like to be able to switch off the light when going to bed.
I can turn off the lights by:
- Using the app
- Using other wall switch with dimmer 2 thanks to association
- Using a scene
Strangely I only cannot turn off the lights by using the connected wall switch, but I can turn it on with the same wall switch ?
What have I tried so far:
- Reboot HC2
- Soft reconfigure device
- Reconfigure device
- Recalibrate
- Excluded the dimmer 2 and included it later
- Reconnected the wires to the wall switch and dimmer 2 module
General information:
Type of wall switch: momentary switch (using S1 only)
Module: Fibaro Dimmer 2 version 3.5
Lights: Two dimmable Philips light bulbs of 15watt each
Controller: Home Center 2 version 4.600
Errors: none
Any suggestions left after trying all the above?
Thank you in advance.
Kevin
Edited by kevin3 answers to this question
