Question about Dimmer 2 module
Guest NinoCasa
Hello everyone, I’m planning to integrate Fibaro in my home and i have a room with double switch and 2 lamps, so i’m wandering if it’s possible to use 1 dimmer module to switch on/off 2 lamps separately but still possible to dimm both of them.
Edited by NinoCasa
If you want to dim independently,  you'll need 2 x dimmer 2.
Guest NinoCasa
    It’s not important to dim independently or at the same time, i’m just asking if i can switch on/off the 2 lamps independently with 1 dimmer module.
    No...to control two lamps independantly you need 2 x dimmer modules.
