FGT full open is not full open
DavidJames
I have installed the FGT on a three way valve for a special purpose.
The "max" command doesn't open the valve entirely. It stops a little gap before, probably to make the return more reliable.
Fine for a common two way valve, but in the case of three way valve this means that the third port doesn't close entirely when it should.
Any tip to avoid this tiny opening?
- The stroke of the FGT is long enough for the valve.
- Putting a spacer after head calibration helps only once. Then there will be an error or recalibration.
Regards
