How to create a scene that a roller shutter opens at sunrise, but not before 6:00 o´clock in the morning
I am absolutely new to Fibaro Home Center etc.
Currently I just own HC 3 and 1 Roller shutter module to get used to the fibaro world.
Now I am trying to create a scene, that opens the roller shutter at sunrise (which ist quite easy using the block scenes). But I want to edit this scene, that even if the sunrise time is earlier than 6 o´clock in the morning the roller shutter opens at 6 o´clock in the morning.
Is there any easy way to create such a scene for me as an absolutely newbie?
Thanks in advance for your help!
Hi I have the following scene in lua which does something very similar, I use a function called suncalc to get sunrise times etc...
What I am doing is setting a start time to open the curtains and then to check if it is light enough using an aeotec sensor to give me a light reading.
local fmt = string.format
function str2sec(str) local h,m,s=str:match("^(%d%d):(%d%d):?(%d*)") return 3600*h+60*m+(s~="" and s or 0) end
function sec2str(sec) return fmt("%02d:%02d%s",math.floor(sec/3600),math.floor((sec % 3600)/60),sec % 60 > 0 and fmt(":%02d",sec%60) or "") end
--Set locals
local currentDate = os.date("*t")
local currentTime = os.date("%H:%M")
local shabbos = fibaro.getGlobalVariable("shabbos")
local sunRise = fibaro.getGlobalVariable("Sunrise")
local sunSet = fibaro.getGlobalVariable("Sunset")
local curtainDuskVariable = fibaro.getGlobalVariable("curtaindusk")
local sunRisePlusOneHour = sec2str(str2sec(sunRise)+60*60)
local sunSetMinusOneHour = sec2str(str2sec(sunSet)-60*60)
--List Curtains Devices
local LivingLeft = 178
local LivingCentre = 183
local LivingRight = 197
local Dining = 259
local Study = 269
local MasterBedroom = 264
--Set earliest OPEN time for groups
local GroupDownstairsFrontEarlyOpenTime = "07:00"
local GroupDownstairsBackEarlyOpenTime = "07:00"
local GroupBedroomEarlyOpenTime = "07:30"
local GroupBedroomEarlyOpenTimeShabbos = "08:00"
if shabbos == "true" then
    GroupBedroomEarlyOpenTime = GroupBedroomEarlyOpenTimeShabbos
--Get Current Light Level For Outside
local LumLevelDeviceId = 280
local LuxLevel = tonumber(fibaro.getValue(LumLevelDeviceId, "value"))
local LuxLevelVariable = tonumber(fibaro.getGlobalVariable("lightLevel"))
local LuxLevelCurtainOpen = 100
local LuxLevelCurtainClose = 20
local checkLuxLevel = "false"
--Open and Close State for curtains
local curtainOpenState = 99
local curtainCloseState = 0
--Set devices in to groups
local GroupDownstairsFront = {Dining,Study}
local GroupDownstairsBack = {LivingLeft,LivingCentre,LivingRight}
local GroupBedroom = {MasterBedroom}
local curtainStateVariable
local GroupDownstairsFrontDirection = "close"
local GroupDownstairsBackDirection = "close"
local GroupBedroomDirection = "close"
--Curtain Control Starts Here
--Group DownstairsFront Curtain Control
if currentTime >= GroupDownstairsFrontEarlyOpenTime and currentTime < sunRisePlusOneHour then
    if LuxLevelVariable >= LuxLevelCurtainOpen then
        GroupDownstairsFrontDirection = "open"
elseif currentTime >= GroupDownstairsFrontEarlyOpenTime and currentTime >= sunRisePlusOneHour and currentTime < sunSetMinusOneHour then
elseif currentTime >= sunSetMinusOneHour and currentTime < curtainDuskVariable then
    if LuxLevelVariable <= LuxLevelCurtainClose then
    else
elseif currentTime >= curtainDuskVariable then
if GroupDownstairsFrontDirection == "open" then
    curtainStateVariable = curtainCloseState
else
    curtainStateVariable = curtainOpenState
for k,i in ipairs(GroupDownstairsFront)  do
    if fibaro.getValue(i, "value") == curtainStateVariable then
        fibaro.call(i,GroupDownstairsFrontDirection)
--Group DownstairsBack Curtain Control
if currentTime >= GroupDownstairsBackEarlyOpenTime and currentTime < sunRisePlusOneHour then
        GroupDownstairsBackDirection = "open"
elseif currentTime >= GroupDownstairsBackEarlyOpenTime and currentTime >= sunRisePlusOneHour and currentTime < sunSetMinusOneHour then
    else
if GroupDownstairsBackDirection == "open" then
else
for k,i in ipairs(GroupDownstairsBack)  do
        fibaro.call(i,GroupDownstairsBackDirection)
--Group Bedroom Curtain Control
if currentTime >= GroupBedroomEarlyOpenTime and currentTime < sunRisePlusOneHour then
        GroupBedroomDirection = "open"
elseif currentTime >= GroupBedroomEarlyOpenTime and currentTime >= sunRisePlusOneHour and currentTime < sunSetMinusOneHour then
    else
if GroupBedroomDirection == "open" then
else
for k,i in ipairs(GroupBedroom)  do
        fibaro.call(i,GroupBedroomDirection)
