Hi All
I want to send this command to node-red. Is this possible with quickapp. I used VD on my HC2
GET /googlehome?announcement=someone%20at%20the%20door HTTP/1.1
Host 192.168.2.160:1880
Thanks in advanced.
Edit this code to your liking. ;)
Edited by Joep
    Hi Joep
    Thanks for your response, I am not very good in this. and not sure where to insert the string in the command using Lua scene on HC3 - Guess its all wrong since nothing happened ;-) I inserted the bold. hope you can help.
    net.HTTPClient():request(url, {192.168.2.160:8080
        options={
          method = 'GET',/googlehome?announcement=someone%20at%20the%20door HTTP/1.1
          headers = {
              headers = {['Content-Type']  = 'application/json'},
          timeout = 2000,
        success = function(response)
                fibaro.debug("Scene1", response.status)
                fibaro.debug("Scene1", response.data)
        end,
        error = function(message)
                fibaro.debug("Scene1", "error:", message)
    Hi @Martin Windsmose,
    try following code:
    Hi Sankotronic
    I get the below error when i try a Quick app. If i create a scene nothing happened. It should come with the string.
    [15.02.2021] [08:57:00] [ERROR] [QUICKAPP435]: QuickApp crashed[15.02.2021] [08:57:00] [ERROR] [QUICKAPP435]: Unknown error occurred: std::exception: 'unable to make cast'
    My flow looks like this, and i should see it in the debug mode on Node-red when i click the quick app or scene
    /monthly_2021_02/image.png.56d5a47e03f76441fb2286b87bee368e.png" />
    Hope it makes sense.
    Thanks in advanced
    Martin
    Please edit:
    with
    And in Node-RED you have to add a http response node so the HC3 gets a reply with a status. Now the HC3 is waiting and waiting and times out at one point. This makes your HC3 slow.
    Hi Joep and Sankotronic
    Apparently its sending something to Node-red
    /monthly_2021_02/image.png.5c44f27fcea927e459de1f4c27318a5f.png" />
    So guess i am closer, just need to figure out why the /googlehome?announcement=someone%20at%20the%20door
    are not beeing send.
    Hello guys
    I see on my HC2 it was marked as string in the VD. do you think thats why is msg.payload: Object empty
    If i just type in chrome: http://192.168.2.160:8080/googlehome?announcement=someone%20at%20the%20door
    I receive the following in node-red
    15.2.2021 13.15.34
    msg : error
    "TypeError: msg.payload.toLowerCase is not a function"
