UDP and Fibaro
Good afternoon
I am trying to send an ascii string to a UDP device via a Lua Scene without success.
Firstly can someone tell me if this is possible as there seem to be conflicting data.
I have scoured the forums and google without success, below is my latest attempt.
This is the error I get [DEBUG] 16:08:03: 2021-02-14 16:08:03.316379 [ fatal] Unknown exception: /opt/fibaro/scenes/23.lua:22: attempt to index global 'Net' (a nil value)
I am new to Lua so please excuse my lack of understanding
Thank you in advance
Regards
Andrew
if (
 ( tonumber(fibaro:getValue(141, "value")) > 0 )
then
socket = Net.FUdpSocket()
local ip = '192.168.0.251'
local port = 3671
local data = string.char(0xaf, 0xbf, 0xcf, 0xdf, 0xef, 0xff)
socket:setReadTimeout(1000)
local bytes, errorCode = socket:write(data, ip, port)
if errorCode == 0 then
  fibaro:log("sent")
else
  fibaro:log("failed")
socket = nil
Hi @fogmajor,
Move your code from scene to virtual device and try.
