Will connected devices still be active and scenes performed even if Home Center Lite is disconnected from Internet?
Hi
I am a newbie, set up everything myself (HCL + Switches, Roller Shutters and Plugs), everything worked OK (manually and with Magic Scenes). But now the connected router with Internet is down and I am unable to restart it remotely. The HCL therefore cannot be accessed over Internet, I cannot go there or send someone physically to reset it manually, at the moment.
Question: Will the programmed devices and stored scenes still be operating as before via the Zwave even if the wifi and/or LAN is down and I cannot control HCL or verify the status for the moment being?
Thank you.
Leo
Yes, the actions are processed locally so in case the WAN connection is down it is still going to work in terms of scenes. For sure now you can not access it remotely as internet is not operable..
    That is what I was hoping :-). Thanks
