Hi All
If I open a browser and paste the string: http://192.168.0.110:1880/googlehome?announcement=someone%20at%20the%20door
My Google Home mini is saying someone at the door
I tried to create a scene, but its not working. (Fibaro Home Center 3)
local address = "http://192.168.2.160:8880/googlehome?announcement=someone%20at%20the%20door"
http = net.HTTPClient({timeout=3000})
http:request(address, {
    options={
      data = requestBody,
      method = 'POST'
I also tried the below code with help from Joep and Sankotronic
I hope someone have any idear what i do wrong.
Kind regards
Martin
6 answers to this question
Check that you are using correct IP, Port and method (These differs from the 3 examples you provided)
    Hi 747
    I have 2 differet setup on Node-red server.  When i test the scene the Home center is in the same IP Range as the node-red. and if i copy the http to the browser it works fine.
    Do you have any ide how to do this.
    I dont use Node-red and i dont have a HC3 (Only HC2).
    It sounds like you are using the Node-red to route data between to different IP subnets?
    Can you ping between these subnets?
    Hi 747
    No i am in the same subnet. Sorry for confusion. Its should have been the same IP and port number on all my test... ( I just create another for test since i did not get it to work i tried to do a new setup on a router i had)
    The only think i want is to open this from my HC3 (I use a VD on my HC2 and it worked very well)
    Ok. So its working when you do the same request from HC2 but not when you are using HC3?
    Im not familiar with the differences for HTTP requests between HC2 and HC3.
    Im not sure which method is the default one when pasting the request into browser, POST or GET, but if it works in HC2 and you use the exact same options/method in HC3 and it doesnt work then i dont know, sorry..
    Hi 747
    I know LUA is differents in HC3 and HC2 so just try to find out the right one on HC3.
    Thanks for you input and have a nice day.
    br Martin
