rojasmusic 0
Hi. This is my first post here. I'm trying to figure out how to add a delay to a block scene in HCL.
I've created a scene where, if electric is enabled in a studio (thru fibaro switch + a contactor) and door sensor is breached, if no motion detected for 15min then turn switch off. The problem is sometimes people open the door, go back into the room to check something (motion detected) so the switch is never off then. I'd like to add a delay so, if switch is on and door is breached, wait 5min and if door has already been closed again, then check motion for 10min and if no motion, then turn the switch off.
Thanks!
