Duplicate Power ON, OFF Events.
Hello, I bought new HOME CENTER 3 Lite and Fibaro Wall Plug. When I click on Icon of this device then I see too much events. See bellow:
When I click to switch off, I get
Could you help me to eliminate this too much events.
Hi
- If you see Action: xxx - that information what action was sent - so if you started scene and send it one you will see it once if in scene you got loop and sending that same action few times you will see it
- If you see ON or OFF that is report sent by device . To receive it you have 2 option: change state of device - manually turn off for example or ask device about state
There is 3 in short time so suggest that device is reporting it. Then go to association and please check with manual is Node ID 1 is set only on report group (if you will have in all 3 device will sent 3 report and you will see them
