Fibaro roller shutter 3 - venetian blind - lamel controlling problem
Hello!
I need to fix a "problem". I use Fibaro roller shutter 3 to control venetian blinds.
After callibration the blinds work fine (goes up, half-way up or 25% down, etc...), but the lamels not change their position as I ask them in the application.
For example I try to close or open the lamels 100% it is no problem, but when I try to make a little setting on its position in the Fibaro app (for example open only about 18 or 25%) the lamels stays the original position -and instead of them moving- the blind goes a little up.
I hope there is a sollution for this in the parameters. Can anyone help?
It is a HC2 Lite so I cab use no LUA scenes...
Thank you!
