qubino smart meter - total watt in app
hello,
is there any way to display total watt consumption in fibaro app?
i got HC3,
i tryed to do it with
and also with aeotec gen5 bat it seems impossible to get see the watt data in the app..
the thing i find ridicolous is that both devices create some child multilevel sensor that are easily readble from the app..
any idea?
tks!
11 answers to this question
Hi. I sent a question to Fibaro earlier regarding HC3 support for Qubino smartmeter,
and got the answer that this device was not supported yet ...
I am using a HC3 and have included a Qubino Smart Meter 3-phase 80 A. It works, not 100%, but well enough to make it possible to see some data. I have not been able to add this to the mobile app, but the data can be seen in the device overview.
Here is an example of what I can read out:
/monthly_2021_03/image.png.fbc841c327f81350e212ce15907c85d1.png" />
Edited by PerABa
Strange on-off pattern of your power consumption
Yes, the device is reading the power consumption in an old heat pump, switching on and off. Also, I suppose that it depends on how often the device is reporting data. In addition to this heat pump, also a circulation pump is attached, which consumes continuously approx. 130 W. This is why the graph never shows 0 W consumption.
Here is what it looks like if I click the "HOUR" tab:
/monthly_2021_03/image.png.a3f6168ff7a06328075bedecc1398afc.png" />
Edited by PerABa
ah, that explains ?
On 2/21/2021 at 4:14 PM, MarcoSmartForYou said:
hello,
i got HC3,
any idea?
tks!
I'm in the same situation as you are. It would be nice to have some feedback from Fibaro...
Just so that we can know if there's anyway to measure your home's overall energy consumption with Fibaro without having to have all your devices IOTed.
P1 Monitor with a Quickapp
Not sure if that's suitable to me as my meter is located outside my house, I don't even know if it has that P1 interface.
You have to find out if it has a P1 interface. If so, the P1 cable can be very long.
Same here. Not able to see the Qubino showing the values in the IOS App.
Same problem for me. Installed the qubino 3-phase smart meter and bought a Fibaro Home Center 3 Lite to read out data. The whole thougt of the installation was to get watt data (and monthly kwh) from a house that I rent out. Anyone can explain how to collect the data into the  Fibaro Home Center?
