Smart implant change icon even switch off after 2 sec.
Hi All
I have a smart implant i use for my front gate. I need to have the device switching off again after 2 sec. to be able to open/Close the gate and therefore i am not able to see if the gate is open or closed.
Is it possible with a scene to tell me if the gate is open or closed. I.E.  one click is open / Close (the gate is marked as open by an Icon -  Even if its switch off after 2 sec) and if I click again the gate is marked as closed. Again only by Icon. I know in Fibaro HC3 is the smart implant will show as "off" Its the same for some of my lamps, cause of the wall switch i have which only need and input to turn on or off
Br Martin
  • 1 month later...
I had the same problem with my Sauna which demands 0,5 sec pulse.
My solution is a fast and ugly one but it works.
I created a virtual device "Binary Switch" which acts as the "indication". I then created two Scenes. When the Sauna is maneuvered on and the "Binary Switch" is off, I have a delay (for you >2 sec) and maneuver the "Binary Switch" on.
Scene two: the other way around when turned off.
Edited by RoReAl
