Haraldinho67 1
Dear forum,
I am experiencing an issue where I have a while true loop to check statuschanges and because I don't want to make the system load unnecessary high, I have put a Fibaro:sleep(1000) in the loop. This gives me around a 1 second accuracy, which is just fine. The problem however is that the system hangs after a while. By adding print statements I was able to track down the issue: at some point, Fibaro:sleep(1000) does not return and my proces hangs. This is the code snippet where that happens:
So in the logs you see it ending on this:
And then it stops... Anybody any suggestions as to why this happens? How can Fibaro:sleep() not return?
I am running HC2 on software version 4.600. Not much going on there, no complicated other scenes, no high loads.
Edited by Haraldinho674 answers to this question
