FBerges 52
Hi
If 2 scenes (let's call them A and B) with a cron trigger 1min. is started e.g. like this
Then something like this is built into A:
Then B will not be started as long as A is still running.
So far so good.
Both scenes say "Allow to restart a running scene:?" on No
But when I look at the CPU load, it is almost 0, but I don't understand that anymore.
Edited by FBergesIf we had a multitasking system and the scenes can be triggered individually and run separately from each other, that cannot be the case.
If we don't have a multitasking system, a CPU load of almost 0 is not possible because this one scene actually swallows all CPU time.
If fibaro.sleep puts the scene into sleep mode and everything else at the same time, I could explain that to myself, but then computing time would be wasted.
Can someone explain that to me, please?
Greetings Frank
