hiding from debug screen onAction: returns
Hi
I'm calling from a scene a QA and would like to hide from the debug return the line launching the QA:
[QUICKAPP595]: onAction: {"deviceId":595,"args":["down"],"actionName":"hueBriControl"}
Do you know if there is any command that can prevent from displaying it ?
br
9 answers to this question
On 2/27/2021 at 3:27 AM, Mateo said:
Hi
br
If you used my
you would have had that as an option.
...but breaking the magician's code, I will reveal it here ;-)
...add this to the QA:
extended will work for UIEvents too
    Thanks @jgab, always carefully watching what you do ... but unfortunately not skilled enough yet to always follow you in all the improvements you propose for the community :)
    will have a look to you QA tools ;) and try the magic trick :)
    to be honest don't see yet how it works :)
    the thing is that when i make a call i see the command in the debug window, and i don't :)
    let see if i can do something with this :)thanks and have a great we
    Well, a lot of the QuickApp framework is written in Lua by Fibaro. When a method is called they log that with
    What the hack does is that we redefine the print function (that fibaro uses) and if the first argument is "onAction: " we ignore it and don't print anything.
    The drawback is that if you yourself in your code do
    it will also not print that. However, we bet on that it is only Fibaro's print that have a "onAction: " string as the first argument.
    On 2/27/2021 at 6:43 AM, jgab said:
    If you used my
    Hello, interesting by this workaround, i'd like to implement it into my QAs
    Can you give me more details about the way to do it ?
    Well, it's just to include the code above - have you tried that?
    I have to create a function for that or put this code anywhere???
    Something like this into my QAs ?
    do
        local p = print
        function print(a,...) if a~='onAction: ' then p(a,...) end end
    function QuickApp:lectureIPX10()
        self.http = net.HTTPClient()
        local address = "http://"..self:getVariable("IPipx").."/api/xdevices.json?cmd=10"
    do
        local p = print
    In you "main file" where you have onInit defined, start by redefining the print function (the do ... end wrapper is just to keep the local p from not clashing with any of you other variables.)
    Fibaro may redefine print themselves before onInit so we can't do it outside of onInit...
    OK fine!!
    Now it's ok......Thanks a lot
