Run scene on power outage notification powerplug
I have bought an Nodon smart plug (ASP 3-1-10)  which is capable to send a notification about a poweroutage.
My HC2 is behind a UPS so it gets the notification.
To gracefully shutdown the HC2 i need a scene which can react to the text given through the API
This is what i get when looking at http://HC2/api/notificationCenter
so the plug is working ok...
I've tried serveral attemts to make a lua script but it's a bridge to far for me because i'm no pro programmer.
Can sombody help me to make the right scene for this ?
Ronald
    I have already the following code which i can use.
    But i don't know how to let it detect the "title" or "text" in the notification table
    If i debug the notification.created or notification.priority i get the expected values back , but how to read the title or text in the second "data" table ?
    so that ik can compare it with a local value to become true and start the shutdown action ?
    %% properties
    %% events
    %% globals
    local notificationtype = 'GenericDeviceNotification'
    function poweroutage()
      local notifications = api.get('/notificationCenter')
      for _, notification in ipairs(notifications) do
        if notification.type == notificationtype then
          fibaro:debug("Gracefully shutdown HC2 " .. notification.id)
          HomeCenter.SystemService.shutdown()
          api.delete('/notificationCenter/' .. notification.id)
        else
          fibaro:debug("there are no more notification with type: " .. notificationtype)
    poweroutage()
    I have managed to make a good functioning script but how to trigger it through the notificationcenter ????
    Somebody ?
    Grtz,
    Msonic
    %% properties
    %% events
    300 GenericDeviceNotification
    --scenebeperking
    if (fibaro:countScenes()>1) then fibaro:debug("Scenebeperking > 1 ... Abort");fibaro:abort() end -- Run only one scene
    local debug = 1 --debug on/off
    local timer = 60
    local counter = timer
    local valuedisconnected = 'AC mains disconnected'
    local valueconnected = 'Power reconnected'
    local table = api.get('/notificationCenter')
    for k, v in ipairs(table) do --first table
      if v.type == notificationtype then
        for k2, v2 in pairs(v.data) do -- second table
            if v2 == valuedisconnected then
               print("start")
               -- begin loop
               while counter > 0 do
                counter = counter -1
                fibaro:sleep(1*1000)
                  if debug == 1 then fibaro:debug("Counter = ".. counter) end
                    for k3, v3 in ipairs(api.get('/notificationCenter')) do --first table
                      if v3.type == notificationtype then
                       for k4, v4 in pairs(v3.data) do -- second table
                        if v4 == valueconnected then
                        print("abort at power return when waiting to shutdown")
                          api.delete('/notificationCenter/' .. v.id) end
                        fibaro:abort()
              -- stop scene
              print("run shutdown command")
              HomeCenter.SystemService.Shutdown()
