Several Heat Controllers have lost connection and no matter what i do they will not reconnect.
Produno
I should probably say this happened after upgrading to HC3.
So far I have 3 Heat Controllers that have lost connection. I cannot soft reconfigure, I cannot reconfigure, I cannot even remove them, it says they are deleted in the console but they are still in my devices. Even when taking them off and placing them on top of the HC3. I also have another unit here that continues to have a motor failure issue.
Any ideas are welcome.
Not the correct place but I should also mention I also have a motion sensor that will not re-connect. I have another motion sensor that reports 0% battery when it still working. I have a smoke detector that also refuses to re-connect and it continues to bleep for absolutely no reason. I also have an rgbw device that refuses to update even though the one right next to it did. My app also reports doors are open when they are not (A good way to scare the mrs in the middle of the night!) and lights are on when they are not.
Other than rgbw the rest started after upgrading to HC3. Not really much of an upgrade -_- it seems...
Thanks.
