HC2-YYYYYY avahi-daemon[19212]: Got SIGTERM, quitting
Hello I found a lot of regular entries in HC2 (4.600) /var/log/messages starting with "avahi-daemon[19212]: Got SIGTERM, quitting.":
This issue is caused by this Fibaro watchdog script: /opt/fibaro/scripts/avahiWatchdog.sh.
This script checks if avahi-resolve command return the proper value, but without dbus enabled this avahi-resolve command returns only: "Failed to create client object: Daemon not running".
To fix this just:
mount -o remount,rw /
vi /etc/avahi/avahi-daemon.conf
uncomment this line:
#enable-dbus=yes
to
enable-dbus=yes
Save.
mount -o remount,ro /
Restart your dbus and avahi daemon with:
/etc/init.d/S30dbus restart
/etc/init.d/S50avahi-daemon reload
After this change everything seems to work fine.
Edited by midi
Further explanation
HC2 now is opensource?
WOW!
    I believe the warranty in such case can be canceled.
    I decided to do so to help Fibaro team to fix some rare errors in HC2 (they can't be detected via HC2 user interface).
    witam,
    pewien, ze Fibaro nie zainteresowany HC2 :)
