HCServer[1442]: segfault at c ip b6f4a1d3 sp a902a0e8 error 4 in libstdc++.so.6.0.21[b6eca000+111000]
Hello, yesterday I have noticed a strange behaviour of my HC2 (4.600):
- can't login to HTTP interface (no response after clicking login button)
- fibaro API returns: HTTP/1.1 503 Service Temporarily Unavailable
In /var/log/messages I found this entry
Anyone has seen this before?
Maybe some memory (RAM) error?
5 answers to this question
    Another case today:
    I have made a further investigation:
    So the HCserver deamon seems to die after the segfault.
    After starting it up with: "/etc/init.d/fibaro/HCServer start" everything back to normal.
    I think some watchdog script in crontab would be useful here...
    No, this is not a problem with RAM...
    MemTest86 v9.0
    For further investigate I decided to enable core dumps in my HC2.
    The core dumps are disabled for default as you see:
    To change this I just added this line ("ulimit -c unlimited") at the end of /etc/profile:
    Remember to restart the Fibaro HC2 (so the HCserver deamon could start with new settings).
    The problem is that root filesystem (/) is mounted with ro flag - so core files can't be stored their.
    To change this just set this kernel parameter:
    To make this change persistent create file: /etc/sysctl.conf and put there a line:
    and after that run:
    Now let's wait for another crash of HCserver... :)
    Edited by midi
    I created a watchdog script to those who need a simple workaround.
    vi /opt/fibaro/scripts/HCServerWatchdog.sh
    chmod 755 /opt/fibaro/scripts/HCServerWatchdog.sh
    Then at the and of crontab just add this line:
    crontab -e
    After that the HCServer will be automatically started in less than one minute after any crash.
    You still need to observe the logs just to be sure that HCServer is not in some death loop (restart over and over again).
    The problem has been reported in Fibaro Support (by me) with ticket: #45142
