I state that I am not an electrician but I think I understand that lights in my system are managed via step by step bistable relay from different switches.
Their behavior is as follows:
  1. I press the button of the switch A and turn light 1 on
  2. I press the button of the switch B and turn light 2 on
  3. I press the button of the switch A and I turn light 1 + 2 on
  4. I press the button of the switch B and I turn them both off
... to be clear something like in the video below genre but working with two different switches...
Could I get the same result by replacing the current relay with the one in the image (FGBHS-213) and setting it to bistable?
Any suggestions will be greatly appreciated! Thank you!
Edited by SimoneR
  • SimoneR changed the title to Replace step by step bistable relay with FGBHS-213
