running scene regardless of conditions
Has anyone experienced problems with HC3 running a scene regardless of the conditions or am i doing something wrong?
I am trying to control a led driver with a fibaro double switch FGS-224 on O1(574) i have the dimming and on/off funtion (long power supply = dimming, short plus toggles between on and off) of the led driver and O2(575) power consumption. S1 is the input of the momentary wall switch auto off (0-0.1s). I try to use a simple scene for good nigh turn of the lights without seeing the status
Declarations:
  conditions = { {
      id = 575,
      isTrigger = false,
      operator = ">",
      property = "power",
      type = "device",
      value = 5
  operator = "all"
Actions:
fibaro.call(574'turnOn') --in this case off for the actual lights
regardless of the measured W at 575 it stills performs the action for 574 when i try to run the scene ( i want this as a upriver slave scene for my master good night scene).
Best regards,
Daniel
if you run scene manually, it will ignore everything and will just run
    Thank you so much that explains it :) wonder why Fibaro didn't reply that to my support request??
    well, there is a basic rule
    If you have a question that other users would know, post it on the forum
    if you have a typical question only fibaro knows, mail support. Don't waste youre time of posting that here.
    Edited by akatar
