Simple scene and number of running instances?
I have two simple scenes that should turn on the boiler pumps (528 and 529) if at least one of the valves (941,942 and 943) is open. And another scene that turns off the pumps when all the valves are closed. If I limit these scenes to a single instance-they don't work, why? And is it possible to combine these two scenes?
%% autostart
%% properties
941 value
942 value
943 value
%% weather
%% events
%% globals
if fibaro:countScenes()>3 then os.exit()end
if (
 ( tonumber(fibaro:getValue(941, "value")) > 0 )
or
 ( tonumber(fibaro:getValue(942, "value")) > 0 )
or
 ( tonumber(fibaro:getValue(943, "value")) > 0 )
or
then
  fibaro:debug("ON  .....");
    setTimeout(function()
        fibaro:call(528, "turnOn");
    end, 5000)
        fibaro:call(529, "turnOn");
    end, 10000)
%% autostart
%% properties
941 value
942 value
943 value
%% weather
%% events
%% globals
if (
 ( tonumber(fibaro:getValue(941, "value")) == 0 )
and
 ( tonumber(fibaro:getValue(942, "value")) == 0 )
and
 ( tonumber(fibaro:getValue(943, "value")) == 0 )
or
then
  fibaro:killScenes(198);
   fibaro:debug("OFF  .....");
        fibaro:call(529, "turnOff");
    end, 5000)
        fibaro:call(528, "turnOff");
    end, 10000)
5 answers to this question
remove the unnecessary %% autostart and use the following example code
local action = "turnOff"
if tonumber(fibaro:getValue(941, "value")) +
   tonumber(fibaro:getValue(942, "value")) +
   tonumber(fibaro:getValue(943, "value")) > 0 then action = "turnOn"
fibaro:call(528, action)
fibaro:call(529, action)
    This beautiful code works great! Thanks
    How best to organize the delay between fibaro:call(528, action)  and fibaro:call(529, action)
    fibaro:sleep(5000);  or  setTimeout(function() ?
    Whatever you like best. Mostly I myself use the fibaro:sleep function.
    Example of somewhat more sophisticated coding:
    Edited by Alex de Bruin
    I tried more complex code, but it doesn't work. The pumps are turned on without delay, and the scene is started for as long as it costs in this line
    Here is my full code
    %% autostart
    %% properties
    941 value
    942 value
    943 value
    532 value
    function getval(valve) return tonumber(fibaro:getValue(valve, "value")) end
    function switch(pump,onoff,wait)
       fibaro:debug(onoff .. " .....")
       fibaro:call(pump, "turn" .. onoff)
       fibaro:sleep(wait * 1000)
    action = "Off"
    if getval(941) + getval(942) + getval(943) > 0 then action = "On" end
    switch(528,action,60)
    switch(529,action,120)
    move the call command behind the sleep.
