On the last Beta version 1.10.0.17 all icons don’t show anymore on the iPhone and iPad app.
re-installing the previous Beta version brought them back, but that support ended so had to upgrade to the latest and they are all gone again.
Attached screenshots from the iPhone app, iPad app shows the same.
I think it the the light version, uses less bandwidth ?
Maybe first try on local network, then remote.
    I am on local network, and I can control everything fine. It is just the icons are gone, not showing.
    As soon as I downgraded they showed like normal, then after the upgrade they are not showing. It is just a bug I am reporting here.
    also did using TestFlight
    I heard more users had the problem. Mine are fine.
    BTW I am on 1.11.0.3 for last beta
    Also look here
    Edited by SmartHomeEddy
    Yep works fine on that version.
    Not sure why it wouldn’t install that version previously through TestFlight.
    Thanks!!
    I have the same problem, with the last beta tester (17) all the icons have disappeared.
    My version of HC3 is: 5.050.13
    Edited by s2kbixio
    If you follow SmartHomeEddy’s link you’ll get a newer version on testflight.
    That works and brings the icons back.
    Not sure why the other link wouldn’t update to the newest version.
    Opssss now working
    thanks!!!!
