Scene to leave bathroom for 30 minutes by double clicking
Hi
I want to make a scene for the bathroom that if I double click the lights will stay on for 30 minutes.This is what I have in Lua but the lights are always switch of earlier than the 30 minutes. What am I doing wrong?
thanks
%% properties
72 value
%% globals
if (fibaro:countScenes()>1) then
  fibaro:abort();
local dimid = 72 -- ID for the dimmer you want to operate
if (tonumber(fibaro:getValue(dimid, "value"))) > 0 then
  local timer = 1800;
  fibaro:debug("Lights on at level "..timer);
repeat
   fibaro:sleep(1000);
   timer=timer-1;
       fibaro:debug("Countdown, current level = "..timer);
  until (timer<1)
  --Once the timer has finished and dimlevel reaches 1, the light will be turned off
  fibaro:call(dimid, "turnOff");
  fibaro:debug("Lights out");
  fibaro:killScenes(25);
7 answers to this question
Is there a specific reason why you don’t use a motion sensor in your bathroom?
" to "
Temat został przeniesiony z "
" do "
    Hi Sjekke,
    I have a motion sensor but I would like to have 2 scenes with this. One which is one for only 5 min (works) and double click for 30 min.
    Hi @SanSuus I use the VSL scene of  @Sankotronicin my Living room. Take a look …
    thanks :-) I will look in to this
    I don't like the motion sensor because the motion has to be continuous for the light to stay on. Where can I order one that stays on for more than a few seconds?
    #fürdőszoba #csaptelep
    There is (of-course) no need for continuous motion. You can change the PIR "save time" to whatever you want.
