Can't adjust slats from my Raffstores with RS 3
Sebastian1982
i try to install my Roller Shutter 3 with my home base HC3 lite.
I have the problem that I cannot adjust the inclination of the slats. I can move the external blinds up and down but I cannot adjust the slats. If I set the controller to 50%, the external venetian blind goes up to 50%. But the slats don't move.
Does Jmd have an idea?
Here is my configuration.
More info needed if someone is going to try and help.  Model number of blinds, wiring diagram would be a good start.
It sounds like you are trying to control two elements...blinds and slats. Maybe you need 2 roller shutter 3s for that??
" to "
Temat został przeniesiony z "
" do "
