HC3 multiple outcome depending on conditions in a LUA scene
Hi, i have a question that i could have done in HC2 but now with the new LUA setup i get lost on the HC3
The scene i am trying to create is started by double clicking on the dimmer and then starts turning of some lights
  conditions = { {
      id = 473,
      isTrigger = true,
      operator = "==",
      property = "sceneActivationEvent",
      type = "device",
      value = 14
  operator = "all"
fibaro.call({[1] = 416, [2] = 417, [3] = 461, [4] = 464, [5] = 474, [6] = 489, [7] = 448, [8] = 561, [9] = 425, [10] = 467, [11] = 422, [12] = 426, [13] = 468, [14] = 490, [15] = 443, [16] = 217, [17] = 465, [18] = 418, [19] = 566, }, 'turnOff')
then it is where it starts to get complicated thereafter i have some led driven downlights and therefore to turn them off need to chek if they are on and then "turn them on again" to turn them off.
so to say if variabel "rooma" (power measeurement) is "on" then turn on Rooma (led push signal)
then do the same for room b, c, d.
finaly i wish to pull Room a,b,c,d power measurements agian to make sure thy now are 0.
I think i have seen solutions on how to incorporate if then in the action part of the lua code but cant find that again.
Best regards,
Daniel
