LUA Szene HC3L Help ?
Guest swissnet3000
Guest swissnet3000
HC3L
Can someone help me ? I'm new to the LUA scene :)
I would like it to be switched on at 06:00 in the morning and off again at 08:00, and on again in the evening at 20:30 and switched off again at 23:30.
  conditions = { {
      isTrigger = true,
      operator = "match",
      property = "cron",
      type = "date",
      value = { "00", "06", "*", "*", "*", "*" }
      isTrigger = true,
      operator = "match",
      property = "cron",
      type = "date",
      value = { "30", "20", "*", "*", "*", "*" }
  operator = "any"
Edited by swissnet3000
5 answers to this question
No, it should look like this!
08:00 or 23:30
Greetings from Germany / Sauerland
Frank
Guest swissnet3000
    Möchte ein und Ausschalten in eine Szene haben.
     Grüsse aus der Schweiz
    ein: 06:00
    aus 08:00
    ein 20:30
    aus 23:30
    honestly this is how it was necessary to create scenes on HC2. Since we have HC3/HC3L, the LUA engine is evaluating anyway the trigger table, long before the scene get triggered (or not - if the pretrigger engine decided, based on the trigger table, to not call the scene at all), this saves resources!
    Therefore is much better to create (in your case) 4 triggers, one for each to the times, and evalute which of them got triggered in "actions" with sourceTrigger.
    In this case the trigger will get called only 4 times, the action as well only 4 times per day (and not 1440 times), no extra calls for os.date necessary each every minute. Additionally easy logic to evaluate who ran the scene, e.g.
    • Like 3
    Guest swissnet3000
    Vielen Dank für die vielen Informationen. THX
    • -1
    Good Morning
    Here is the scene you would like to have.
    On the left side you have a 1 minute trigger, which means every minute the right side is run through 1 x.
    On the right side you can see the process.
    I get the current time and compare it with the specifications.
    Well, you can see what's going on for yourself.
    You only have to set the IDs of the lamp correctly.
    Greetings from the neighboring country
    Frank
    Guten Morgen
    Hier ist die Scene die du gerne hättest.
    Auf der Linken Seite hast du einen 1 min Trigger, das bedeutet jede Minute wird die Rechte Seite 1 x durchlaufen.
    Auf der Rechren Seite siehst du den Ablauf.
    Ich hole mir die Aktuelle Zeit und vergleiche sie mit den Vorgaben.
    Na ja du siehst ja selbst was da passiert.
    Nur die ID´s der Lampe musst du noch richtig stellen.
    Grüße aus dem Nachbarland
    Frank
    Hier mal ein Paar Quellen für Infos.
    Declaration
    Aktion
