Jay Ess 6
Hi I have a scene which is triggered by a switch, i want to switch off the switch after 60 minutes, what would be the best way of doing this?
so far i have a simple way but it does not seem to be clean.
I have a loop in the scene which runs for 60 minutes and then at the end of the loop sets the swicth to off,
I have two problems with this, one if I turnoff the switch manually and then on again it causes an error in the debug, this might not be a big thing but it does not feel right from progaming side. the other issue woudl be if the system reset during this countdown I would loose the countdown and the switch would stay on when it should be off.
Thank you for your help.
