FlipC 0
I'm new to this, can I make this work on HC3? I'm trying to edit the code, but I'm just getting the same error. In the code below I have marked the line that refers to the error.
"[ERROR] [CONDITION_ERROR]: (load):35: unexpected symbol near 'local'"
%% autostart
%% properties
2093 value
HC-Humidity-Fan-Control
Script to control humidity in your bathroom.
Author: Peter Gebruers, aka "petergebruers". Meet me here:
Or here:
The full project is on the Fibaro forum:
See also:
Licensing, warranty and liability, governed by:
"Attribution 4.0 International (CC BY 4.0)", available at:
Version 1.0.0: public release
-------- USER SETTINGS BEGIN --------
-- sensorDeviceID is the ID of the (slave) device which reports humidity.
-- If you want to test this script, set it to any dimmer, it will act
-- as a "humidity" sensor by dimming up and down.
-- Check if this ID matches the value in the header of this script!
local sensorDeviceID = 2093
-- fanDeviceID is the ID of the (slave) device which controls the fan.
-- This scene automatically detects if it is a switch or a dimmer.
-- as a fan. Brightness will be an indication of fan speed.
local fanDeviceID = 2278
-- humidityUpperLimit and humidityLowerLimit determine % level at which
-- the fan should start/stop (taking into account delays and timing below).
-- I recommend 80-70 or 75-70 but feel free to experiment and share your
-- thoughts.
local humidityUpperLimit = 75
local humidityLowerLimit = 70
-- delayMinutes delays the start of the fan, when humidity first exceeds
-- its threshold. This avoids turning on the fan while you are in the
-- shower. Can be set to 0.
local delayMinutes = 20
-- fanRunMinutes limits the maximum amount of time the fan can run
-- without interruption. The assumption is, if the fresh air is humed,
-- the fan could run forever. Used with fanSleepMinutes to determine an
-- on/off regime. Note: stopping and starting this scene resets this timer.
local fanRunMinutes = 2*60
-- fanSleepMinutes determines how long the fan should stay off, after
-- fanRunMinutes was exceeded. The assumption is, weather conditions will
-- have changed after several hours, so it is worth trying again.
local fanSleepMinutes = 4*60
-- timeSpeedupFactor makes time appear to go faster if you set this
-- above 1. Setting it to 60 will cause a one minute period to elapse
-- in 1 second. This greatly helps while debugging this script.
local timeSpeedupFactor = 1
-- autostartSleepSec delays start of this script at boot time,
-- to allow for startup of all HC services.
-- A value of 30 - 45 seconds is recommended.
local autostartSleepSec = 30
-- minFanLevel sets a the lowest level which can be
-- send to the fan. An induction motor will stall if this
-- value is too low and then it might overheat.
-- If your fan exceeds 30 W, use a proper "inverter drive"!
local minFanLevel = 50
-- function log(msg) is a shortcut for fibaro:debug.
-- It can also be used to remove debugging. To do so,
-- Set log to an empty function.
local function log(msg) fibaro:debug(msg) end
-- local function log() end
-------- USER SETTINGS END --------
4 answers to this question
