Comparing and replacing Auxiliary Variable Value (HC3)
Greetings, i'm trying to setup are a scene where as soon as the reading from a qubino smartmeter changes, i update the value on a variable that i'll use later for something else. For this i´m tryng to compare the reading from the smartmeter to the variable aux, if this reading is different then i want to replace it's value with the most current value.
However, i can't save or run the scene.
I'm very new with this and wuld apreciate any help, thanks in advance
