PWM dimmer on RGB Controller 2
I am using PWM dimmer (2 lines for DC and 2 lines for LED load) to control white LED bar with dimming. Now I don't know how to connect to and configure Fibaro RGB Controller 2 which can control LED dimming using this PWM dimmer and by fibaro. Appreciate for any advice. Thanks.
If your LED bar has just two connections, I would try replacing the PWM dimmer with the Fibaro RGBW device.  Use diagram 3 in the online manual
, noting you only have one strip.
