rasenkantenstein 0
Hi all,
I would like to use the Smart Implant to open a gate connected with a NICE MCA2/MC424 control.
When opening the lid I do see the following setup:
Also, here's a screenshot of the manual:
There's already one external (Hörmann) switch connected to the terminals 9/10 and 12/15.
From what I can see I would need to connect the implant's power to terminals 9 and 10 (red and blue cables) together with the Hörmann cables. The Hörmann cables are used with a remote in order to use one remote control for the garage door (by Hörmann) in conjunction with the gates by NICE. Generally, the Hörmann transmitter also provides a switch function. Thus, I would probably try to use them as a binary input for the smart implant. The implant's output would be connected to NICE terminals 12/15. (as an alternative, I would put the Hörmann cables and the implant's cables into the same terminal.)
Would that setup work?
Another question:
Would there be a way for the implant to check if the gate is opened or closed?
Best regards,
Konstantin
Edited by rasenkantenstein4 answers to this question
