Is there a QA for setting up the Neo Coolcam Siren to use primarily as a doorbell?
When I used HC2, a VD was done that addressed this, but I didn't find one for HC3.
Or is there someone who could at least send me a template of the device?
Thank you
wondering what you will doing after you got template :D
Guest kallecux
Hi @Michal-Pu I wrote this for me:
You have to change the ID's and create some Button.
Greetings!
Let it DingDong by:
fibaro.call(QA-ID,'DingDong')")
Edited by kallecux
    Hi @kallecux, thank you, i will try
    Edited by michal_pu
    Thank you
    I'm curious, why you need VD or QA for that?
    first I wanted to set everything from the panel (melody selection, volume, use, shutdown at night), but QA will not be needed, I have fixed the parameters that I will use ....
