FIBARO System Update 4.610 for Home Center Lite
T.Konopka
Version 4.610
Important notice:
All Z-Wave thermostats require performing device soft-reconfiguration to operate properly (not applicable to updates from version 4.601 beta).
New improvements:
- Important security fixes.
- Modified Z-Wave thermostat support - each setpoint type has its own device tile (requires device reconfiguration).
- Support for FIBARO Walli Controller (FGWCEU-201).
- Support for FIBARO Smart Implant (FGBS-222) version 5.2.
- Support for Era Inn Edge Tubular Motor version 1.1 or higher.
- Support for Heatit Z-Temp2 version 1.1/1.2.
- Support for Heatit Z-TRM3 version 4.0.
- Tedee lock plugin.
Resolved issues:
- HomeCenter.SystemService.reboot() function does not work.
- Some Sonos devices are not discovered by the plugin.
- Blocked UDP ports prevent the detection of some devices on the network.
- Unable to add FIBARO RGBW 2 (FGRGBW-442) in Security Mode.
- No scrollbar on device group selection window in block scenes.
- Z-Wave device firmware update attempt results in system hang-up and 503 error (requires device reconfiguration).
- Some actions that should be available for Roller Shutters in Magic scenes are missing.
- No data from YR Weather plugin.
- Other minor fixes.
  • - Support for Steinel IS 140-2 version 1.0.
    - Support for Steinel L810 LED iHF version 1.1.
    There was a mistake in the changelog. The above features were NOT INCLUDED in the installation package.
