Also in this version almost all device and scene icons are wrong!!!!!! ?
I don’t have this issue. All custom icons are still visible in the app version 1.11.0 on my iPhone
Most of my selected icons are in the new app   ?
Lets hope Fibaro will fix it soon.
//Sjakie
pitty we cant go back to previous version
ios 14.4.2
13 hours ago, Rover said:
icons are wrong
It sounds like you have all different icons?
(I still have the right icons, no problemo)
    @T.Konopka and @m.roszak
    Could you help me please in repairing this very unpleasant problem?
    You need to login locally to the gateway, then custom icons will be synchronized.
    HC3 login is already local:
    I have also tried https://192.168.1.21/app/dashboard
    Or will it take a day to synchronize?
    I think he means with the app locally login
    Hi @SmartHomeEddy,
    How is the app to be locally to login? The app has the FibaroID as well as the local IP of the HC3.
    I don’t know if this does the job. You can logout and log in (offline) with ip address etc. That goes without the Fibaro ID. Hope it will solve your problem ??
    Edited by SmartHomeEddy
    mmm, for me same problem with the icons from HC3 in the (Apple) mobile App.
    I remove the app en reinstall, now all my uploaded icons, give "?", all original icons from HC3 are correct.
    Tip from @SmartHomeEddy for local login, don't help.
    ps; I have in my FibaroID 3 Homecenters, 2x HC2 and 1 HC3.
    Update:
    - remove App
    - download App again
    - login locally (not with you FibaroID, see App below right side to click)
    - all icons are now correct
    - logout locally
    - login with FibaroID
    15 hours ago, twanve said:
    Update:
    - remove App
    - logout locally
    It works ??
    TNX @SmartHomeEddy and @twanve !
