It's not stated, but I assume with latest software version a soft-reconfiguration is enough for the Fibaro thermostats?
Regards, Olaf
This Important Information is missing cant believe it....
This is not that easy as it seems.
Every thermostat need reconfiguration.
Soft version will do the job but for most thermostats (supporting more than one setpoint type) model will alter and some of the IDs of the devices will change anyway.
I will forward request for adding this information to the changelog.
Michał
Added to the changelog on forum that soft-reconfiguration is ok ;)
Will be updated on the server in few minutes.
HC2 with 4.610.
Did a softreconfig of a Ztrm3.  Can't change temp setpoint from Fibaro Android app (v.1.27.0)
Then tried a full reconfig of Ztrm3. This did not solve the issue either.
I am on it.
I see one issue in theory with using this with the app, could you confirm by suspicion?
Setting heating setpoint is possible, other does not work.
Issue does not occur in web interface.
Web interface work. Android phone app and Tablet app have the same issue.
Can not change temp setpoint. Only turn themostat on/ off.
Reported to the developers, we will look into it.
Hello everyone
Have some problems with Benext thermostats ,with my heatit all went fine just reconficurate and works..
but my Benext wireless thermostats (180122) is no longer a thermostat it has become a temp sensor .
any one have that problem
The soft configuration is needed also for "The Heat Controller FGT-001" devices?
I run a fibaro binary sensor for thermostat a heating plan and a fibaro switch.
what needs soft reconfiguring?  Binary or review the heating plan?
In this case - nothing.
@Jaapkooi
After full reconfiguration its the same?
That is odd.
Could you download device template and share it here after reconfiguration?
I also experience the same issue. Only Web interface works
The 4,610 update should perhaps be withdrawn until this Heatit ztrm3 problem has been fixed...
