Interesting thermometer to share a website
Source code:
Demo page:
It must be downloaded from the
clone or downloaded.
Copy the application directory to your WebServer and you can rename it to temperature, for example
Example:
Create a TMEP database on the server and import the mysql-db-full.sql file
Set the login name and password to the database in the config.php file
When everything is done correctly, a web page will be displayed.
It's all about installing the program.
I have my thermometer here:
This page works for me and I send data to the sql database using the DzVents script with the DOMOTICZ program. Now I would like to use it to send HC3
I need to send temperature data from my HC3 to the TMEP sql database. Can anyone help me?
Edited by Laco Jurdik
    I have an outdoor temperature and humidity sensor in my HC3.
    I would need to send data to mysql database: 192.168.1.200:3306
    HC3:
    ID:142    NAME: TempOut
    ID:143    NAME: HumOut
    /monthly_2021_04/2021-04-04.png.3601306228437ed85d7ceff501aab9b9.png" />
    MariaDB:
    Database name: TMEP
    Table: tme
    kdy = when day and time (example 2019-09-20 13:15:00 )
    teplota = temperature °C (example 10.9 )
    vlhkost = humidity (example 60.8 )
    Can anyone help me create a script?
