The Heat-It thermostat (V1) and the Spirit Thermostat are not shown in the new app (V1.11) as thermostats under More... > HEATING
also I cannot edit the settings like temp of those thermostats under the Room devices
I am not sure this started with firmware V 4.610 or the app when updating to V1.11 (the new app)
Edited by Twannie
Thermostats devices (com.fibaro.setPoint, com.fibaro.fanMode, com.fibaro.operatingMode device types) are not available (never were) in the new mobile app for HC2/HCL.
Only old application will show them.
    Aha, apologies. I was not aware of that..
    The Danfoss LC-13 are shown though!!
    Edited by Twannie
    Yeah, Danfoss LC-13. FGT-001 and one of old Horstmann devices are available :)
    No plans to add the others too?
    Any plans to support the HeatIt thermostats in the new mobile app?
    I will ask and let you know if updating thermostat support regarding HC2/HCL platforms is planned and let you know.
    I have learnt that this is not in plans in near future as thermostat model from HC2 differs a lot from HC3.
    This will require fair amount of work.
    For now direct control of other thermostats is available using old mobile app (currently one bug there on HC side, working on it).
    You can always use heating zones for control those for now.
    My Heat-it thermostat communicates each minute or so with the HC2
    Can I decrease this?... Device is excluded from polling
    I disabled "cool" and "eco mode" setpoint devices and hided them.
    Now communication decreased a lot. Don't ask me why!! ?
    • 2 years later...
    I would like to know how are they different? The setpoint group is still there. It is possible to control the setpoint with virtual device! So how is it that its now different from hc3? As you probably know the old app does not work for most new devices... and the most idiotic suggestion is to use fibaro heating/panel zones for setpoint controlling, if you have a on the wall thermostats the heating panel will overwrite the changes made from the wall thermostat. Unusable - good luck explaining it to your grand parents or any old person. All the *1 star ratings* you get for releasing the broken (yubii) app doesn't make any sense, it should have been fixed long time ago. People will never support this planned obsolescence.
    Edited by JDF
