  • 5
(New) Firmware 5.2 Smart Implant
There is new firmware available for the Smart Implant:
Update of 2 SI went without any issue's.
Updated to 5.2
Lets see, if there no more message (Hardware failure..) because of an 4 meter long wiring.
Remarkably, despite engaging with support over a year ago and being assured it was being worked on, this update doesn't include a fix for the "Released" CentralSceneEvent, which is sent after a "HeldDown", before the key is actually released! When the key is released another "Released" is sent.
    Mine failed
    /monthly_2021_04/FB7A31D6-17E6-4B0C-9E31-B01FA2DBC61C.jpeg.b90075b353609645d3889eea466140b8.jpeg" />
    Takes 10-15 minutes, but mine ok (test device)
    On 4/4/2021 at 2:17 PM, SmartHomeEddy said:
    Mine failed
    I have the same error in 3 devices
    Devices needs to be included non-securely to make it work.
    Impossible for me, the devices are behind some air conditioning slits that I would have to break to access :(
    This must have been warned
    I also have to dismantle my alarm, that is not so easy. So I think I will survive without the update. It worked the last year, so it will work the next year (I hope).
    Hello all,
    First attempt>>>>>> failed
    Also the next 6th attempts failed I am waiting for a better update.
    also secure included?
    On 4/3/2021 at 2:46 PM, Tundel said:
    Updated to 5.2
    Have your hardware failures stopped?
    I might consider upgrading if it fixes the random hardware failure messages.
    Yes, after update there no more hardware failure messages
    Get out of here!!!
    I will have to carve out some time for an upgrade ..... it won't change or make-up for the fortune I spent on the electrician replacing SI's and DS18B20's.
    does anybody else have problem with DTH22 and Smart Implant after firmware update?
    After I updating the firmware the the smart implant shows 0°C and 0% humidity from DHT22.
    I have tried another DHT22 and reconfigure already. Not working.
    Guest Andrew Riley
    On 4/4/2021 at 10:17 PM, SmartHomeEddy said:
    Mine failed
    I have the same issue - recommendation?
    UPDATE: removed from secure mode, update worked, readded as secure. ¯\_(ツ)_/¯
    /monthly_2021_07/image.png.da6e6b1c5df50223488a407555378d04.png" />
    Edited by Andrew Riley
    Hi @Andrew Riley Exclude the smart implant from your HC3, include the smart implant as non secure, then do the update. That should do the job.
    I'm sorry, but I must be total noob here. Where can I find the firmware file 5.2 standalone to download?
    Do Fibaro even give out the Firmware for the smart implant? I'm using homeseer and wish to update my smart implant to 5.2?
    Fibaro devices can only updated through a Fibaro hub.
