Smart Implant FGBS-222 - Smartthings - Garage Door
Hi, I have connected my Smart Implant with my garage door and it works fine by manually pressing the button on the module to open and close the garage door. However, when I pair the module with Smartthings the standard on/off Z-wave handler loads, which doesn't provide the ability to set parameters and I cant open or close the garage door via Smartthings or Alexa.
I therefore think that a custom handler is required for Smartthings, however, I cannot find one via Google.
Can someone please confirm if I am barking up the right tree and if so, where can I get the correct custom handler for Smartthings?
Edited by Hohmes
ut make sure that you have the latest firmware update through your home center.
