Smart implant and waterflow sensor
claudent
Hi, I am using 2 waterflow sensors (cold & hot water) connected to the IN1 & IN2 (analog inputs) of smart implant. Actually I don’t know where to instruct the smart implant that 1L = 500 pulses ( revolutions). Can someone please help?
thanks a lot.
Unfortunately Smart Implant (or any other Z-Wave module I know) gives you this feature.
Smart Implant can:
- check the state on the input (as binary one), NC/NO
- measure voltage on the input (with or w/o pullup for passive or active analog sensors).
It does not count pules, it was not designed for that.
@claudent you could also consider using a cheap pre built module that converts frequency to voltage first, and then use the implant to measure the voltage. Let us know if you try this!
Eg this one
