I use a API script to start a scene:
this used to start the scene.
Now I get the response:
what goes wrong? 34 looks like an unsigned int to me.....
Greets, John
Why are you using %26 on the path? That's the encoded code for ampersand character but you should be using the character & itself.
    Thanks! That did the trick....
    Guest cuprum
    From RFC 3986 - URI Generic Syntax:
    . Percent-Encoding
    So, unfortunately the %-encoding masks the meaning of '&' and makes id equal to "34&action=start"
