Hi
Something also changed using the Heat-It thermostat on 4.610
I noticed the "Heat temp setpoint"  only is changed by the Heating Zone using the Heat-It V1 thermostat
The Heat-it has a "energy save setpoint", a "heat setpoint" (and cool) and a possibility ("switch") to change it to "Heating" or "Energy Save Heating"
If I put the temp higher in the heating zone (e.g. manual mode) the "switch" stays on "Energy Save Heating" so the heating does not start
So in short, the Heating Zone only changes the "Heat" setpoint and if the Heat-It is on Energy Save Heating the temp will not change.
    I did a few soft re-configurations again, which solved the issue
    Edited by Twannie
