only string variables instead of the fitting label on UI elements
I just installed my Fibaro HC3L a few days ago.
The first thing I found really annoying is the fact, that some UI elements just do not contain the proper label, but instead only the label variable.
e.g.:
find.fibaro.com - every! single! label does not show up, but only the variable of it (even the cookie text... :D)
In the HC configuration there are missing e.g. all tooltip texts. at least most of the time.
From time to time it works - no idea in which case:
/monthly_2021_04/image.png.1e08201a86fc1f87ec6df6609cb60ede.png" />
I'm using SW-Version: 5.070.42
What can I do?
Thanks,
Christoph
you can try to delete browser cache
EDIT: Found the solution my self... changed to Polski language and back - then all was good.
Hi Christoph - did you ever find out how to fix this... my find.fibaro.com page is just like yours - and this is the first time I enter the site!
So don't think this is a cache issue!
/Dan
Edited by DanDK
Found a solution my self.
