The weather display from the web site and iOS apps is still completely wrong.
/monthly_2021_04/image.png.3868afc8c23a139b2e924315649fb0fb.png" />
It's 11pm at night, and the web app is showing a bright sun.
The iPad app always shows a moon no matter what time of day it is.
Rubbish.  Why has it been so hard for you get this right for sooooo many years Fibaro????
The weather here is also @abuse@
/monthly_2021_04/image.png.a081f503352eed4464fb7ac96ae550e4.png" />
But YR Weather is completely right, it is just bad weather ?
you might get only bad icons (not every condition seems to get proper icon), the condition code and all other weather data is ok. But this is known, and will get fixed soon.
Edited by tinman
@tinman thanks for explanation.
I have no clue how they are working (if they are working) if I did the same  in my job I should be un employed.
Finally I was glad push msg where working again they relase an update 5.070 and  push msg disturbed and not working properly.
Update App great all my added icons gone how it is tested by a blind person?
Strongly I believe there are diffrences in HC3 boxes despite they run the same FW.!
Fibaro test and it is working or the dont tell the truth>>> on my HC3 box it fail.
For the good understanding I struggle with this for alsmost one year.
I dont complain my box is running (missing some key performers) and a tramendus time consumer for the operator!
Cheers,
//Sjakie
I didn't notice any problems with weather condition on GUI home page and on mobile apps, but maybe this is because I'm using my Weather State and Forecast VD with Weather provider plugin:
Still it would be nice if Fibaro can also make available wind speed in m/s (meters per second).
the waether service provide have weather codes, and weather data. So that what the plugin is reading. Then the plugin is trying to map proper icon, with nice picture, to the waether condtion code. There are much more condition codes than icons, and in the past Fibaro used yahoo codes, later translated yahoo to yr, and now mapping directly (because the YR API changed) .. anyway, it is just icon.
i don't think i'm blind, nor the other testers.
there is one difference between each every HC3, the environment in which is being used.
see above.
Honestly, i had 4 such customers, 1 fixed, 1 gone, 2 left. Hard job, lot of hours to find the reason. On the other hand hundreds of happy customers. From my point of view, one unhappy cusomer destroys more than 100 happy customers "are worth". Unfortunately one can't make everybody happy or fix every issue (no matter if user or environment or system based).
