LUA / Scene to read an Advanced parameter
I need please to read an advanced parameter from a LUA scene or Virtual Device. I was able to set a value for a parameter by using the following code:
function sirene_volume(DeviceID)
    fibaro:call(DeviceID, "setConfiguration", 1,1,3) -- This is Parameter 1 with size 1 and value 3 (volume 3 for siren)
sirene_volume(15) -- 15 is device ID
I need to read the parameter value before I do set it. Any thoughts?
I have HC2 with firmware 4.590
4 answers to this question
Use the following function:
In your case call read_par_value(15,1) to get the value of sirene parameter 1
    @Alex de Bruin
    It works!! Many thanks, I am able to read parameters now.
    Thank you again and appreciated.
    A bit shorter and simpler version:
    Yes it works also, many thanks for your support.
