pflugj 13
I am using the "Universal Binary Sensors" as connector for up to 4x Temperature Sensors.
So I developed a small PCB that holds the
1. UBS connector
2. push-connectors for the sensors and some Resistors to avoid ringing
3. A tiny MeanWell 12V 2W PSU
I also printed some enclosures for this.
This fits well into a standard British 4x4 wall-box
When I started the system I only had a few devices and a few tries of inclusion and the Sensors where working.
Now there are about~135 devices and more are coming!
Usually at every door in the house there are the least
1x Sensor in the floor and a
1x Sensor at door handle height
usually the same on the opposite site of the door.
So up to 4 Sensors per door
Currently I have ~15 of them installed but the final installation will have at least 30 or more of these devices.
Meaning I currently have about 60 Temperature sensors apart from the from ~22 Multi-sensors (Ceiling).
In case you wonder:
I am using the concrete slabs/floors as "Thermal Stores" (AKA: concrete core cooling)
And I am heating the floor with "SELF regulating heater cables"
Always 2 circuits per room and a total combined wattage of ~75W per square meter (@10 degrees).
This is only happening during day times and with SOLAR Power ONLY!!
To Include the device you simply have to
1. Put the HC in learning mode - of course
2. Apply power and the usual triple click on the B-Button.
3. once you found the right rhythm for the 3x clicks you might get the message: Added device complete .. or so.
Eventually the UBS show as fully configured!
Unfortunately that does NOT mean that everything is working!
The UBS should show up with at least:
1x Master
3x Motion Sensors
1x Scene controller
PLUS
1-4 temperature Sensors
Usually I ended up with a device that was either:
NOT Configured
or
Showing only a part of the inputs and no temperature sensors
or
All inputs and Temperature Sensors showing "O"
or
NOT updating the temperatures
etc!
When the temperature sensors do NOT show up,
then there is also the possibility of some wiring problems:
So please check the wiring 1st!
The usual advice then is:
Exclusion and Inclusion again and again - UNTIL it shows up as expected!!
and bring the device closer to the controller!
Great - I can not move the controllers any closer
because at the time of the inclusion:
"The temperature Sensors have to be connected!!!
(Temperature Sensors are wired into the floor and to the doors)
I also do "FULL DEVICE RESET" in between.
Unless you are 2 people, you have to place a switch into the supply lines of the UBS to do a reset!
So I also prepared a switch to be temporarily installed.
After weeks of inclusion and exclusions I was sick of this time wasting process as it almost NEVER seems to work.
But I think I found a way.
As usually, when the UBS shows up with NO Sensors I:
1. Try to configure the device for Temperature sensors: report 0.5 degree temperature changes ( I used all the defaults except for the un-used IN1 and IN2 , I configured them as NO)
2. The association MUST be set from Endpoint 0 > Group 3 > Controller (Single Channel)
If this is not set, the temperatures will not update!!
Sometimes I found the association set after inclusion most of the times it was not set!!
If the home Center does not allow you to do any of the above ( for whatever reason) ALWAYS do a
3. SOFT - reconfiguration next!
Usually more and more devices appeared or sometimes even disappeared!
I had UBS where I needed to do that 2x times but I also had some where I had to do that 20x times!! if I remember correctly
So do NOT give up eventually I got them all configured and Temperatures are reported as expected.
I hope this helps anyone who might have similar troubles with UBS
Best regards
Jürgen
4 answers to this question
