Motion detection for turn on the light (Fibaro Motion Sensor) and then dim it to 40%
Hello!
I have a fibaro motion sensor and LED strip to dimm it.
I need to implement next scenario:
If I in home LED on for 40% and when motion will be detect it dimm up to 100%, after 15 minutes it will dimm to 40% back.
When I go out home (global "InHome" - Yes or No) LED turn off.
So, the code:
%% properties
234 value
214 value
%% globals
-- Configuration of variables (id of motion sensor must be entered under %% properties above---------------------------------------------------------------------------------------------------------------------
local scene = 30 -- ID of this scene
local motion = 234 -- ID motion sensor
--local motion2 = 170 -- ID 2nd motion sensor
local switch = 214 -- ID of lamp
-- local switch2 = 152 -- ID of 2nd lamp
local InHome = fibaro:getGlobalValue("InHome")
local starttimer = 120 -- time in s, the lights stay on (+ time set in motion sensor - par. 6)
---------------------Script-----------------
fibaro:debug("start")
if (fibaro:countScenes()>1) then
    fibaro:debug("stop scene");
    fibaro:abort();
-- SWITCH LIGHT ON/OFF (if not day)
if (tonumber(fibaro:getValue(motion, "value")) > 0 ) and InHome == "Yes" then
    --Turn Light(s) on
    fibaro:call(switch, "setValue", "100");
    --fibaro:call(switch2, "turnOn");
    -- timer start und configure
    timer = os.time();
    while os.time() - timer < starttimer do
        fibaro:sleep(1000);
        -- set timer to zero if another motion is detected during delay (set in starttimer)
        if (tonumber(fibaro:getValue(motion, "value"))) > 0 then
            timer = os.time();
      if InHome == "Yes" then
        fibaro:call(switch, "setValue", "40");
    else
        fibaro:call(switch, "setValue", "0");
fibaro:debug("end");
fibaro:killScenes(scene);
It work good, but it have one problem: if i InHome=Yes and there is no motion it first dimm to 40% and then after some time (different every time) it turned off.
May be someone can find a problem in scene?
Thank you!
